AW: [post in English] Bezzera 3000AL Lever operated machine: volume is too low?
That's perfectly normal.
The volume of coffee you get depends on the volume of coffee meal you use (e.g. 14 or 16g) resp. the grind (how fine). I prefer a concentrated shot for its taste - then I also get 1 cup only (approx. 25 ml).
If you grind coarser and use more coffee (e.g. 16g) it's possible to obtain about 50 - 60 ml.
I prefer a longer preinfusion (20 - 25 sec.) and no coffee dripping until I let the lever rise up again. To achieve that, I adjust the grind accordingly - grinding fine enough (but not too fine - what would result in an overextraction, the lever rises much too slowly etc.).
And the coffee must be really freshly roasted, about 2 weeks after the roasting day it's possible to let the coffee run about 25 - 30 Sek. Old beans tend to early blonding and I would not let the coffee flow longer than 15 sec. So fresh beans are indispensable...
If you want to have the same level in the cup as when using a pump driven machine, you need to grind coarser (but, to my mind, still there should be no drops during the preinfusion period), using more coffee meal and very fresh beans. But still it remains a question of taste. I often prefer less volume and enjoy this very complex buttery experience
