Ich fände es ganz nett, wenn der Eröffner des Themas den Titel korrigieren würde. Bei dem Wort "Espressi-Sorten" dreht sich einem ja der Magen um.
Das klingt ja wie "Zücker-Arten" oder "Salze-Streuer"
Viele Grüße,
Jukka
Viele Grüße,
Jukka
La Pavoni Europiccola Bj. 1995 - Mahlkönig Vario Bj. 2009 - Momentan in der Verkostung: Moak Brasilea (Espresso) - GEPA Bio Café Organico (Filter und Stempelkanne)
Danke für die Links. Ich hätte auch noch einen zu bieten, den mir cappufan netterweise geschickt hat. Vielleicht sind ja noch mehr Vario-Besitzer betroffen:
Recalibrating the Baratza Vario [photos] - Grinders • Home-Barista.com
LG,
Inalina
Solis Crema SL 70 + Mahlkönig Vario
Ich vermelde hiermit die Behebung meines Vario-Problems.
Mit folgender Anleitung war das Tuning super easy:
Quelle: CoffeeGeek - Espresso: Grinders - Espresso, The Baratza Vario Grinder Owner's ThreadMove the macro (right)
lever all the way UP. you should not hear any loading on the motor. Now
bring the left arm UP at the mid point of the micro scale you should begin
to hear motor loading...increasing as you go all the way UP. Your grinder
has the newest secondary calibration feature. This new adjustment screw
allows for easy for dynamic calibration. The new screw is a 2mm Allen head
screw located between the discharge chute and the calibration grommet you
removed earlier. It is a round hole. With this, we now set up the Varios a
little bit coarser at the factory and allow for easy adjustment toward the
fine direction. Simply set the macro arm all the UP and the micro mid way
and turn the 2mm screw clockwise (looking up at it) until you begin to hear
motor loading. There is no grommet to remove and the process is very
easy.Our goal was to come up with an easy, user friendly way to fine tune
the grinder. The original adjustment proved to be difficult and not doable
with the grinder running. This new screw ONLY allows you to fine up the
grind from the factory setting, you cannot use this screw to make the grind
coarser than the factory setting. For this one would need to move the
original adjustment spline."
Ich hab zwar zuerst in die falsche Richtung gedreht (Mühle aufrecht, Imbus von unten eingesteckt in Uhrzeigerrichtung) bis ich das Schräubchen komplett rausgedreht hatte, aber als ich dann logischerweise die Schraube in die andere Richtung eingedreht habe, also von mir aus entgegen dem Uhrzeigersinn, war sehr bald eine Änderung des Motorengeräuschs hörbar und nun schafft es die Vario auch meine Solis zu verstopfen.
LG,
Inalina
ich lese gerade dieser Bericht.
Ich habe ein Mahlkönig Vario und währe sehr an dieser Bericht interessiert, leider funktioniert der Link nicht mehr, können Sie mir wissen lassen wo das mit der Einstellungschraube stand sodass ich es nachlesen kann?
Herzlichen Dank im Voraus.
Buck88
Hallo, habe es glaube ich gerade gefunden bei Coffeegeek.
Sollten Sie noch was besseres haben, lese ich das natürlich auch gerne,
Noch ein schönes Wochenende.
Buck88
Hallo Galgo,
Ganz herzlichen Dank für die schnelle Antwort.
Mein Vario wird morgen nach Hamburg geschickt zur Reperatur werde dann mal Anrufen das die so ein Werkzeug mit zurück schicken.
Wenn du in meiner gegend bist ein Espresso (auch Zwei) wartet auf dich als Dankeschön.
Buck88![]()
