Hi
I have made an temperature-device.
It is really nothing new, i have used it myself on my old Izzo Alex II and my current Izzo Alex Duetto.
And the cool thing is that you can measure the excact temperature of the water.
I used it on my old Heat-exchanger-Izzo to flush the correct amount of water, and on the Duetto, i use it to set the offset to the correct value.
Is works as the Erics's Device, is easy to install and cost a lot less.
I make these devices myself and the adaptors that goes in to the grouphead as well, so it is a private sale.
The installation is very strait-forward.
You just replace the 6mm "inbus mutter" in the grouphead (save the gasket) with the one that i supply and gently press in my thermometer.
easy peasy
I have made some for the other guys in the Danish Espressobar.dk and they are very happy with it
it is tested and works/fits with the following machines and all other E61:
Izzo
Vibiemme
ECM
Expobar
Bezzera machines with E61
And it should fit other machines that use the E61 grouphead.
Offset before ( and i have used this setting for 3 months and couldent belive that i needed so "hot" water)
And the device shows the true water-temperature
Offset adjusted, and now i can believe what the machine tells me.
Payment with Paypal - 63 euro that include shipping to germany.
Please send me an email on a.dyrby@gmail.com as it is more easy to keep track
- You can reply in german, i read it fine, but my writing is terrible.![]()
