DF83 vs. P100
Diskutiere DF83 vs. P100 im Mühlen Forum im Bereich Maschinen und Technik; It is a report about the comparison between DF83 with 83mm Itamil burrs and P100 with 98mm SSP HU burrs. It shows their performances in doing Pour...
  1. #1 Mandarinfish, 20.01.2023
    Mandarinfish
    Mandarinfish Mitglied
    It is a report about the comparison between DF83 with 83mm Itamil burrs and P100 with 98mm SSP HU burrs. It shows their performances in doing Pour over.
    Recipe :
    Coffee beans:15g
    Hot water (92 degree Celsius): 250g ( tap water filtered through Brita)
    Dripper: Origami
    Filter paper: Origami
    Grind size: medium fine
    Technique: YT Vince‘s one pour technique
    Coffee: Light roast
    left: DF83 right: P100
    57F38171-1E2E-4617-9F0B-2195ED5D8CC7.jpeg 59BAA0F4-0133-4D31-BAE3-73B1C2B4C01A.jpeg 404B4BF2-AAB7-4A26-A8DC-6037C11591D5.jpeg A91DE139-C087-46A7-9D59-4825D509C54A.jpeg DD82B30A-B000-40B0-93E4-5F1434E3D729.jpeg
    coffee beds:
    188228D9-FAB6-4662-877C-E1E254B62599.jpeg 2FE1866A-B495-44AA-91E5-94B19735C348.jpeg F2A7F22E-491A-40D1-B937-2320C1D0996C.jpeg E765B206-5D09-45B9-A956-0CB2BD3E0DE2.jpeg
    Findings:
    I tried my best to grind coffee at similar size and the coffee beds show that DF83 produces more fines. I did a blind test with the filtered coffee at warm and cold temperatures twice. When I drank them warm, I picked P100 out as a more favorable one each time. DF83 has an obvious bitter taste; P100 tastes intensive and no bitterness; it has more clarity with better notes separation. When they were consumed cold, the bitterness of DF83 faded out and tastes smooth; whereas acidity of P100 comes to front.
    My thoughts: basically they are both capable of making enjoyable filer coffee but with no doubt P100 stands out between these two.
    WernerFrisur, cloudconnected, oliccino und 11 anderen gefällt das.
  2. #2 Wipeout267, 20.01.2023
    Wipeout267
    Wipeout267 Mitglied
    Thanks for the comparison and pictures. I only do pour overs once in a while, so I do not have too much experience with brew parameters and how they change the taste in the cup. Is there a reason why you went for a quite short extraction time of 1,5mins? The recipies that I know are more in the range of 2-3mins.
    Do you think that comparison would yield the same results with a different recipe?
  3. #3 Mandarinfish, 20.01.2023
    Mandarinfish
    Please check this video
    This experiment shows that the most flavours are extracted out within 2 minutes.
    As you can see in my pictures, the coffee is ground finer and Origami is a relatively fast dripper, so I think the time should be fine. Of course there is possibility to optimize as well.
    Wipeout267 gefällt das.
  4. #4 Mandarinfish, 20.01.2023
    Mandarinfish
    The fact that DF83 produces more fines won't change. If a different recipe is similar to this one, I guess this comparison will be valid.
  5. noioso
    noioso Mitglied
    Das Mahlgeräusch klingt wirklich ziemlich nach Bohrmaschine. Da warte ich lieber ein bisschen länger auf mein Mahlgut. ;-)
  6. #6 shadACII, 20.01.2023
    shadACII
    shadACII Mitglied
    Wirkt auf mich nicht schlimmer als das Kreischen der 64MPs in der kleineren Version. Mit dem Unterschied das letztere bei Espresso schonmal 30 s brauchen und nicht nur 10 s.
    BTT: Interesting to hear, that even the Espresso focussed 98 mm HU Performs better for Filter than the Stock DF83. Actually Surprised me a bit, but then all 98 mm SSPs seem to lean towarss higher clarity.
    Technokrat gefällt das.
  7. #7 Mandarinfish, 20.01.2023
    Mandarinfish
    It is loud, but not so disturbing for me. Because it grinds pretty fast. ;)
    BTW it vibrates truly a lot.
  8. noioso
    noioso Mitglied
    I can imagine. Sorry for taking your thread off topic. I actually meant to post this video in the D83 main thread. If a mod feels like moving the post, it would be much appreciated.
  9. #9 Mandarinfish, 20.01.2023
    Mandarinfish
    I assume It shines at dealing with light roast, either espresso or pour over. I found 98 SSP HU can extract more flavours out of beans in comparison to Itamil. The taste is brighter.
    Actually I also compared P100 with the Kinu M68 yesterday. P100 has unfolded more layers than M68.
    Clarity: P100>DF83>M68
    mochalattecino und shadACII gefällt das.
  10. #10 Mandarinfish, 20.01.2023
    Mandarinfish
    No worries! It's totally fine. :D
  11. #11 shadACII, 20.01.2023
    shadACII
    shadACII Mitglied
    I feared this, seems to be connected together. The highest clarity tends to come with brightness and acidity.
    Good to hear that the DF outperforms the M68 in terms oft clarity, while not being overly bright.
  12. #12 Mandarinfish, 20.01.2023
    Mandarinfish
    Actually I'm not so suprised. Don't forget M68 is a conical, similar to Niche. If M68 is a bass, then P100 is a tenor. Each plays its role in coffee world. :)
    For those who like lively acidity, P100 makes a nice pick. ;)
    Technokrat, mochalattecino und shadACII gefällt das.
  13. #13 cloudconnected, 25.01.2023
    cloudconnected
    cloudconnected Mitglied
    The P100 costs more than four times of the DF83.
    What do you think is good price/taste eletric mill single dose brew only grinder?
  14. #14 AlexanderD, 25.01.2023
    AlexanderD
    AlexanderD Mitglied
    I think for the price of the DF83 and the flexibility it gives with any range of roast level, you just can’t go wrong.
    Mandarinfish und cloudconnected gefällt das.
  15. #15 Mandarinfish, 25.01.2023
    Mandarinfish
    IMHO for the grinder itself DF83 is quite solid and worth every cent. But if you want a SD brew only grinder, you should probably wait a while for some better burrs.
    Whereas P100 is high end. The design and build quality are of course on a next level for the extra paid price. I would choose SSP brew burrs over HU burrs if it is meant to be a brew only grinder.
    I enjoy using them both! You can pick either of them within your budget.
  16. #16 cloudconnected, 25.01.2023
    cloudconnected
    do you mean a df64 with sweet lab or ssp mps is bettt then the stock df83?
  17. #17 Mandarinfish, 25.01.2023
    Mandarinfish
    No, I don't own a df64 with those mentioned burrs. I can't judge if they are better brew burrs than the stock df83. What I said is that there are prossibly in the future a series of new 83mm SSP burrs being available which perform better as brew burrs than the stock itamill burrs.
DF83 vs. P100
DF83 vs. P100 - Ähnliche Themen
  1. [Verkauft] Mühle DF83v
    Mühle DF83v: Hallo, nach langem hin und her, habe ich mich dazu entschlossen meine Lagom P64 zu behalten und die praktisch neue DF83v wieder zu verkaufen. In...
  2. [Verkaufe] DF83 - Verbesserte Mahlgrad Anzeige/Sticker
    DF83 - Verbesserte Mahlgrad Anzeige/Sticker: Hallo zusammen, da es sich bei individuellen Aufklebern durch den Grundpreis nicht lohnt nur 1 Aufkleber zu bestellen, hatte ich für meine neue...
  3. Single Dosing: Femobook A68 oder DF83V ???
    Single Dosing: Femobook A68 oder DF83V ???: Zurzeit habe ich eine DF64 mit SSP HU und Hopper im Einsatz. Überwiegend trinke ich fruchtige Espressos. Diese bekomme ich auch gut eingestellt...
  4. [Verkauft] Probarista G-Iota Pro83 v2, DF83 v2
    Probarista G-Iota Pro83 v2, DF83 v2: Ich überlege meine DF83 v2 abzugeben. Es kündigen sich neue, interessante Mühlen an. Gekauft bei Homebarista aus Belgien im Februar diesen...
  5. Unterstützung bei der Ausrichtung der DF83
    Unterstützung bei der Ausrichtung der DF83: Habe mir (gebraucht) eine DF83 geholt und inkonsistens in den shots bemerkt. Markerprüfung zeigte das nur an einer stelle sich due Farbe abreibt,...
