Francis Francis X1 temprature issue (english)
Diskutiere Francis Francis X1 temprature issue (english) im Reparatur und Wartung Forum im Bereich Fragen und Tipps; Hi, I have a problem with my francis Francis X1 (first generation aluminium boiler) it only heats to 80°. I opened it and tried some setting with...
  1. #1 MartinP, 27.05.2020
    MartinP
    MartinP Mitglied
    I have a problem with my francis Francis X1 (first generation aluminium boiler) it only heats to 80°. I opened it and tried some setting with adjusting the resistor (1K ohm) but nothing really changes.
    I also tried other settings with the 10K ohm resistor (this ones is normally glued as fixt setting). But I don't get the temperature above 80°...
    I measured the water temperature with a thermometer directly at the nozle when it comes out.
    If I pull out the thermometer out of the boiler the water temperature easily goes up and over the 100°.
    Anybody with similar problems and a fix?
    Kind regards,
    Martin
  2. #2 bon2_de, 27.05.2020
    bon2_de
    bon2_de Mitglied
    probably the thermometer is faulty! This is a common defect of the Francis X1. It cannot be repaired as it is a fluid filled capillary part. Buy a new one, it's can easily be replaced.
    Regards
    Armin
    benötigt gefällt das.
  3. #3 MartinP, 27.05.2020
    MartinP
    MartinP Mitglied
    Thanks for the fast reply!
    Do you mean the thermometer (RTD) wich goes in to the boiler ?
    Because I thought of that as well but I cant seem to find a name or part number for this to order.
    regards, Martin
  4. #4 bon2_de, 27.05.2020
    bon2_de
    bon2_de Mitglied
    Yes, you're right. To be sure you can measure the temperature of the boiler in that gap where the probe of the thermometer is applied but I think there will be no difference to that measurement you already did. I know that it is very hard to get spare parts from Francis but you can buy similar thermometers (same diameter, 52mm i think) online.
Francis Francis X1 temprature issue (english) - Ähnliche Themen
  1. Teilesuche für Francis Francis X1 (Gen. 1 mit Aluboiler)
    Teilesuche für Francis Francis X1 (Gen. 1 mit Aluboiler): Hallo Zusammen, ich repariere gerade meine Francis Francis X1 (1. Generation mit Aluboiler). Wie allseits bekannt ist sie nicht die haltbarste,...
  2. Francis X1 (2012) wirft RCD
    Francis X1 (2012) wirft RCD: Hallo, vom Einschalten an nach 30 Sekunden bis zu einigen Minuten fliegt der 30mA RCD. Mit einem Multimeter im Schutzleiter misst man 30, 40,...
  3. Francis Francis X1- jede Sekunde ein akustisches Signal
    Francis Francis X1- jede Sekunde ein akustisches Signal: Hallo Leute, letzte Woche habe ich meine X1 gereinigt, Boiler zerlegt, Maschine entkalkt. Sie funktionierte einwandfrei. Nun gibt sie nach dem...
  4. Francis Francis X1 (Messing) entkalken
    Francis Francis X1 (Messing) entkalken: Hallo liebes Kaffee-Netz, hab meine Francis X1 Alu gegen eine mit Messing Boiler (X1 Trio?, ESE) getauscht (gebraucht gekauft, gebeizt und neu...
  5. Francis X1 ohne Platine
    Francis X1 ohne Platine: Hallo Forum, ich habe eine defekte Francis X1geschenkt bekommen. Angeblich soll die Maschine nicht mehr richtig heizen. Als die Maschine...
