Was bringen Aeropress Filter im Siebträger
Diskutiere Was bringen Aeropress Filter im Siebträger im Grundsätzliches Forum im Bereich Fragen und Tipps; There is a new wave of using aeropress or v60 filters on top and at the bottom of the PF in order to extract more out of the coffee. This will...
  1. #1 Denis, 02.05.2019
    Zuletzt von einem Moderator bearbeitet: 02.05.2019
    Denis
    Denis Gast
    There is a new wave of using aeropress or v60 filters on top and at the bottom of the PF in order to extract more out of the coffee. This will decrease the channeling effect, at-least this is what they say.
    This has been brought now by Rao on his blog, but this method has been used many years ago by alot of people, it was common when people started to use ek43 on espresso and because they could not grind fine enough with light roasts they would use a filter paper under the coffee, and this would slow down the flow.
    I did test is a bit, and i don't like it, what I can say really fast about it:
    - the coffee flows and looks better but the taste is not ok (you get more disturbing, grassy, cacao, biterish taste, not clean). I was using the Uraga Ethiopia and the stone fruit was gone but more sweetness and more cacao came, loosing clarity for sure (and I am not referring to bright acidity).
    - by adding these 2 filters you create additional hydraulic resistance, you mimic a add of "fines" this forces you to grind coarser.
    - the paper produces more crema/body in the cup, but its like a fake effect, I find it similar to "pressurized portafilters from commercial machines".
    A friend of mine did try it and he measured 30 espresso with refractometer, and the change is minimal on medium roasted coffee. He used Robur (20-21 EY) and Ek43s (Titus carrier, SSP burrs, aligned to 0.005) -23-25 EY with a 2 month old italian blend.
    Probably this helps the pucks that are not well prepared with WDT, or grinders that are not homo gen in grinding. Give it a try if you want.
    And as a little method to check how much you extract, after you are done extracting, flip the puck and see the bottom. If you have black spots that resemble to a jam then you didnt extract everyting out of it. In the first photo you can see a black spot on the right side of the puck. That is what you want to push out of the coffee in the cup. As you can see my puck is almost empty.
    As you can see, the filters add so much hydraulic rezistance that the upper part of the coffee puck is compressed, that zone is getting "Dead" and you cannot extract from there, this is bad for sure (see the first picture).
    IMG-20190502-WA0047.jpeg IMG-20190502-WA0045.jpeg IMG-20190502-WA0043.jpeg IMG-20190502-WA0041.jpeg IMG-20190502-WA0039.jpeg IMG-20190502-WA0032.jpeg IMG-20190502-WA0030.jpeg
    rebecmeer gefällt das.
  2. #2 Geschmackssinn, 02.05.2019
    Geschmackssinn
    Geschmackssinn Mitglied
    did You try just 1 Filter Paper? (the Top, or Bottom? what effekt?)
    i know that technique quite a while as well, but never tried it.
  3. Denis
    Denis Gast
    I don't own a refractometer yet, but will have one soon.
    My friend measured today 30 espresso shots using 2 filters, 1 top, 1 bottom, no filter , with both grinders and the different on a medium-Italian blend roast was under 0.5 in TDS. He is using Duomo WDT (so his distribution is always the same) and he is using a Kees van der Westen Speedster with idro-compresomatic (so the forces that apply on the puck are retained by the PPIC - expansion room in 0-3 bar range, and 3-9 bar range are controlled by the spring in the idro-compresomatic. It is a machine that helps alot to extract more.
    Maybe on such a machine the filter paper doesn't add anything, but on a classic pump machine with a stronger impact in flow when switching from low to high, the filter might help. Until I can measure TDS I cannot say a lot, because this is all subjective opinion.
  4. #4 jazzadelic, 04.05.2019
    jazzadelic
    jazzadelic Mitglied
    Moderator
    Bitte grds. auf deutsch kommunizieren. Englischsprachige Foren gibt es bereits genügend. Denis kann ausreichend deutsch. Danke.
    Technokrat, onluxtex, Francois1 und 7 anderen gefällt das.
  5. cbr-ps
    Naja, sein Translator kann holprig deutsch ;)
  6. #6 jazzadelic, 04.05.2019
    jazzadelic
    jazzadelic Mitglied
    Moderator
    Dann soll er mal den hier probieren www.deepl.com. Setzt natürlich eine korrekte Fütterung voraus.
    Gandalph, Technokrat und brrrt gefällt das.
  7. Denis
    Denis Gast
    Sich über die Fähigkeiten von jemandem lustig zu machen, Sprache zu sprechen und zu schreiben, ist nicht etwas Reifes. Möglicherweise, anstatt zu stoßen, solltest du einige Informationen posten, die Leute verwenden können.
    Deutsch ist meine 4. Sprache und ich habe erst vor 1 Jahr Kontakt damit aufgenommen.
    Dirk2/3, Wispr, since4 und 2 anderen gefällt das.
  8. #8 DaBougi, 04.05.2019
    DaBougi
    DaBougi Mitglied
    Er hat sich wohl über die bisweilen ulkigen Auswüchse der Software amüsiert, wohl eher nicht über dich.
    AeroBTM, Dale B. Cooper, Azalee und 4 anderen gefällt das.
  9. #9 cbr-ps, 04.05.2019
    cbr-ps
    Alles gut, dann nutze sie gern hier, über fremdsprachliche Fehler von Menschen mache ich mich nicht lustig, nur über wirr interpretierende Maschinen.Es tut mir leid, wenn ich mich da missverständlich ausgedrückt habe, wollte dich nicht beleidigen.
    Ich bin fast täglich im Job mit deinen Landsleuten in Kontakt und da akzeptieren wir selbstverständlich beiderseitig, dass unser Englisch nicht perfekt ist, das ist kein Problem.
    Ich finde die Initiative von @jazzadelic gut, hier im Forum wieder zu einer einheitlichen deutschen Forensprache zurückzukehren, dafür nehme ich gern auch menschengemachte Stilblüten in Kauf.
    Dale B. Cooper, onluxtex, sokrates618 und 4 anderen gefällt das.
  10. brrrt
    brrrt Mitglied
    Er hat sich nicht über dich lustig gemacht.
    Das ist klasse. Weiterhin gutes Gelingen. :)
    AeroBTM, NiTo und cbr-ps gefällt das.
  11. Denis
    Denis Gast
    Der Kaffee wird rötlich/braun gefärbt (im gleichen Zeitraum/Verhältnis), was bedeutet, dass ich mehr extrahiere (zumindest in der Theorie). Der Geschmack wird besser, mehr Körper, Schweiß und keine Adstringenz oder Bitterkeit.
    Bis Ende dieses Monats werde ich ein Refraktometer besitzen, damit ich einige wirklich objektive Meinungen abgeben kann.
    Hat es jemand versucht?
    rebecmeer, jazzadelic und Geschmackssinn gefällt das.
  12. clucle
    clucle Mitglied
    Also doch gut? 2 Filter? Vorher gespült, beide?
    Ich würde es auch gerne richtig testen, aber mit meiner cremina bräuchte ich kleinere Filter mit 49-50mm Durchmesser. Bisherige Versuche gelangen nicht aufgrund von channelling am Rand mit reingequetschtem Filter, der sich dann natürlich am Rand falten muss, um reinzupassen. Zuschneiden ist zu aufwändig, um es häufig zu nutzen. Habe ich aber noch nicht probiert.
    Durchaus interessant finde ich, abgesehen vom möglicherweise besseren Geschmack, dass die Nutzung von Papierfiltern gesünder sein soll als Metallfilter - aber das nur am Rande.
  13. Denis
    Denis Gast
  14. Chill
    Chill Mitglied
    ist bestimmt auch ne gute methode um den temperaturfühler zu platzieren, mit nem aeropress filter über dem pulver wir der filter nicht mehr ins pulver eintauchen werde ich auf jeden fall mal testen...
  15. Denis
    Denis Gast
    Wir haben einen Filter unten, jetzt bringen wir einen metallischen Filter oben.
  16. Chill
    Chill Mitglied
    sind die filter denn zurechtgeschnitten?
    habe heute mal nen aeropress fikter versucht der ist vom durchmesser minimal größer und passt nicht in meinen st.
  17. #17 Phoenixxx3, 08.05.2019
    Phoenixxx3
    Phoenixxx3 Mitglied
    Gibt es nicht auch ein IMS Sieb mit Metallfilter statt Löchern? Hat das schonmal jemand probiert?
  18. Chill
    Chill Mitglied
    der metallfilter interessiert mich, wenn der exakt in den st passen würde wäre perfekt....will den wie gesagt nur zum messen nehmen.
    wird aber, wenn der Standardmaße hat aber nicht in den st passen.
    ich habe einen feinen metallfilter speziell für die aeropress der nicht passt, den kann man aber auch nicht zurechtschneiden.
  19. Denis
    Denis Gast
  20. Chill
    Chill Mitglied
    Klar geht es mit ausschneiden is aber nicht sehr praktisch
Was bringen Aeropress Filter im Siebträger - Ähnliche Themen
  1. Schwarze Kunststoffblende an Silvia anbringen
    Schwarze Kunststoffblende an Silvia anbringen: Hallo, ich habe schon einen Thread zu dem Thema gelesen, aber komme nicht weiter. Ich habe eine schwarze Kunststoffabdeckung gekauft und möchte...
  2. Italbar 100/DEL 2GR. in Gang bringen!
    Italbar 100/DEL 2GR. in Gang bringen!: Hallo Community! Ich bin neu hier und habe mir vor kurzem eine Italbar /Sacher 100/DEL 2Gr. gekauft! Diese mochte ich nun reparieren , weil der...
  3. Ab 1. April: Neue Vorschrift für Röster u. Händler, welche Kaffee in Verkehr bringen.
    Ab 1. April: Neue Vorschrift für Röster u. Händler, welche Kaffee in Verkehr bringen.: Herkunftskennzeichnung primärer Zutaten ! Diese gilt für die Verpackung und Darstellung in Online-Shops. Kurze Zusammenfassung: Neue...
  4. Eureka Inox Cover selbst anbringen
    Eureka Inox Cover selbst anbringen: Hallo zusammen, ich bin gerade dabei mir eine neue Mühle zu kaufen und habe mich optisch in die Eureka Mühlen verliebt mit dem Chrom 17NX Inox...
  5. Manometer anbringen an M6 Gewinde
    Manometer anbringen an M6 Gewinde: Aloha, Ich habe eine Rancilio S26 bei der ich gerne ein Brühdruck Manometer anbringen würde. Die Brühgruppe hat einen ähnlichen...
