Pavoni: Handhebel hat viel Spielraum nach rechts und links - normal?
Diskutiere Pavoni: Handhebel hat viel Spielraum nach rechts und links - normal? im Reparatur und Wartung Forum im Bereich Fragen und Tipps; Das Ganze hat sicher auch damit zu tun, dass La Pavoni seit geraumer Zeit zu Saeco gehört. Die Einführung des unsäglichen Plastik-Kolbens soll...
  1. #41 vectis, 11.04.2019
    vectis
    vectis Mitglied
    Die Einführung des unsäglichen Plastik-Kolbens soll aufgrund einer Entscheidung eines Menschen aus dem Management geschehen sein, der vermutlich nie eine solche Maschine benutzt hat. Da ging es einfach mal darum Kosten zu sparen, denn "Plaste & Elaste" ist nun mal billiger als Messing:eek:
    Bei Francesco kann man noch das nachlesen:
    We are at the end of 90's, are now almost 40 years from commercialization of the first Europiccola and all the changes have not altered the original draft, the modes of operation have not changed and aesthetically the machine is riched and modernized. Thousands are his admirers all over the Western world, are born several forums and amateur sites and the exchange of experiences between users show one of problems that assume a greater importance of others. In practice, many users complain that, having made some coffee, the temperature of the group becomes excessive, the water comes out at a temperature higher than normal and the quality of coffee is unsatisfactory.
    These reports come directly from users or through the Service Centers, to La Pavoni who initially modifies the calibration of the pressure in an attempt to decrease the operating temperature of the boiler, with reducing the pressure from 0,8-1,0 atm. to 0,5-0.8 (1996).
    Subsequently la pavoni modifies the group by introducing inside a sleeve in teflon in order to improve the thermal performance of the group. In practice, you will return to the origins, to the model of 60's, with the difference that the use of sleeve in Teflon instead of sleeve in brass increases the diameter of the group of 2 mm and the resulting increasing of filters and filter holder (2001).
    [​IMG] [​IMG]
    The changes described above are the most significant and important, but many others were there the changes in 50 years from when the Europiccola enchanted its admirers, and this makes practically unique every machine output from its factories.
    Und das noch:
    ... IF HAVE A TEFLON PISTON
    If you have a machine produced between 1996 and 2006, the piston is made of teflon instead of brass. It is not clear the reason for which La Pavoni make this choice but it is clear the reason why she returned to use again the brass piston: frequent loosening of the shaft of the piston and fracture after 10 years of usage, if you were lucky.
    [​IMG] [​IMG]
    ithe piston can partially unscrew from shaft and avoid to flow water in the group the piston is designed to break after a certain number of years of use
    Möchte man also eine noch "echte" La Pavoni sein eigen nennen, dann hilft nur der eventuelle Rückschritt auf die älteren Versionen.:rolleyes:
    joost gefällt das.
  2. #42 chromo23, 15.04.2019
    chromo23
    chromo23 Mitglied
    Nachdem ich Erfahrungen mit Pavonis aus fast allen Jahrzehnten gemacht habe kann ich nur sagen, dass ich total glücklich bin eine alte Maschine aus den 70ern zu haben. Ich würde nie nie niemals auf die Idee kommen mir nochmal eine Neue zu kaufen. Das fängt schon beim Sound an, den der Kesselverschluss macht, wenn der Boiler so dickwandig ist wie bei den Alten. Und je neuer die Maschine waren, mit denen ich zu tun hatte, desto älter sahen sie aus !:confused: (Da sind die Besitzer natürlich auf etwas schuld mit dran).
    Es gibt auch einen direkten Zusammenhang zwischen Modelljahr und Anteil der Plastikteile (bzw. Teflon).
    Warum also eine Nagelneue? Du gibst mehr Geld für nicht unbedingt besser aus. Einen Überhitzungsmod, wie Joost schon erwähnt, rein und du hast ein Top Gerät!
    joost und vectis gefällt das.
  3. #43 chromo23, 15.04.2019
    chromo23
    chromo23 Mitglied
    Sorry, aber den Nachtrag kann ich mir einfach nicht verkneifen:
    Nur weil man kann aber nicht muss, sollte man nicht gleich kaufen!!!
    Mal das Portemonnaie wieder zumachen, durchatmen und kurz an die anderen Menschen und die Umwelt denken!
    vectis und joost gefällt das.
  4. joost
    Oh Mann... jetzt wächst die Lust schon wieder o_O
    .. und den Spezial-Messingring zur Fixierung eines neuen Kesselbodens mit Pressostat-Technik sollte man eigentlich in Kleinserie deutlich günstiger hinbekommen. Wer stellt sich mit an?
    chromo23 gefällt das.
  5. vectis
    vectis Mitglied
    Hehe:D
    womöglich könnte Dir geholfen werden, denn ich hätte da etwas Passendes bzw. könnte eventuell gerade eine günstige 1975-77er aus Italien besorgen.
    Eine Kleinserien-Produktion des Messingrings klingt interessant, vor allem auch rein vorsorglich für den Fall, dass die vorhandenen Heizelemente irgendwann mal das Zeitliche segnen (was ja gelegentlich vorkommen soll...)
    chromo23, Li-Si und joost gefällt das.
  6. joost
    geh weg, Du Monster :D
    Wieviel?
    brrrt und chromo23 gefällt das.
  7. vectis
    vectis Mitglied
    Langsam, gaaaanz langsam, lieber @joost.;)
    Ich muss erst einmal in mich gehen, ob ich die 1978er mit dem nur in diesem einen Jahr verbauten Schalter wirklich veräußere (obwohl ich weiß, dass sie bei Dir in den besten Händen wäre).
    Was die in #45 erwähnte Europiccola aus Italien betrifft, da bin ich noch am Verhandeln bzw. hoffe den Anbieter zu einem Versand nach Deutschland bewegen zu können.
    Konkrete Preisverhandlungen dann zu gegebener Zeit bitte per PN.
    Vectis
    joost gefällt das.
  8. vectis
    vectis Mitglied
    ... oder der Pate der Diven macht mir das berühmte Angebot, das ich nicht ablehnen kann:D;)
    joost gefällt das.
  9. vectis
    vectis Mitglied
    und die Antwort aus Italien lautet leider:
    Salve, no mi dispiace.
    Ich kann es ja verstehen. Es mag nun mal nicht jeder seine angebotene Maschine ins Ausland versenden.
    Aber ein Versuch war es wert, eine gut erhaltene Europiccola für 120,- in nördlichere Gefilde zu bringen.
    joost gefällt das.
  10. joost
    Püüüh- Glück gehabt :oops:
  11. #51 chromo23, 16.04.2019
    chromo23
    chromo23 Mitglied
    Du scheinst es ja richtig nötig zu haben ;)
    Soll ich dir bescheid geben, wenn mir eine über den Weg läuft?
  12. Li-Si
    Li-Si Mitglied
    @joost Heißt es nicht, "ein Mann, ein Wort" statt "bloß nicht" ? :D:p;)
  13. vectis
    vectis Mitglied
    Mooooment!
    Hier ein Bildchen zum "Anschmeicheln":D
    Bei meiner liegt allerdings das originale Abtropfblech ohne die Plastikwanne auf dem Basisteil drauf (so war es ja auch ab Werk bei dieser Version), ansonsten ist es ein Zwillingsschwesterlein, bei dem lediglich ebenfalls bereits ab Werk die Wasserstandsanzeige etwas schief steht weil das obere Kesselteil mit dem dortigen Anschluß offenbar einen Tick verdreht angelötet wurde. Dessen ungeachtet ist alles dicht und die bella Macchina funktioniert einwandfrei.
    joost gefällt das.
  14. Li-Si
    Li-Si Mitglied
    Von der würde ich mich auch anschmeicheln lassen. Den Fuß finde ich so schön.
  15. vectis
    vectis Mitglied
    @Li-Si und alle anderen,
    Ja, sie gefällt mir ja auch, vor allem wegen des Schalters mit Minimo und Massimo, aber "schon" mit Kontrollleuchte, was es in anderer (SchalterForm bei der Vorgängerversion ja auch schon gab. Warum nun dieser hier zu sehende Schalter nur im Jahr 1978 von La Pavoni verbaut wurde, bleibt etwas unklar.
    Vermutlich war es nicht gerade der stabilste Schalter wegen der Mittelrastung für sozusagen "ausgeschaltet" und Licht aus.
    Aber um den eigentlichen Thread nicht vollends zu torpedieren (Verzeihung @NDNKL, aber vielleicht wars bisher ganz interessant für Dich), hierzu nochmal die Feststellung, dass bei diesen Versionen der Europiccola die Handhebel ganz und gar nicht "wabbeln", sondern minimales Spiel aufweisen, sofern sie nicht schon arg benutzt wurden.
    Daher ist die Handhabung sehr angenehm und die verarbeiteten Komponenten sind schon relativ wertig.
    Ich kann sie nur empfehlen und deswegen bleibt sie nun doch bei mir:p
    Aber in den italienischen Portalen tauchen die 70er Europiccolas immer mal wieder auf und manchmal in erstaunlich gutem Zustand;)
    Li-Si und chromo23 gefällt das.
  16. #56 chromo23, 16.04.2019
    chromo23
    chromo23 Mitglied
    Maaaaan... das ist doch gemein! Jetzt hab ichs doch gemacht :rolleyes: Das Abtropfblech stand schon lange auf meiner Liste von Dingen die ich nicht wirklich brauche und nun habe ich es gekauft. Es gehört schon einfach dazu!
    Da predige ich Wasser und trinke Espresso....:)
    vectis gefällt das.
  17. vectis
    vectis Mitglied
    finde ich auch.
    Und weil es so nett aussieht, hier eine 1969er mit Alu-Abtropfblech mit noch eckigen Löchern.
    Meine älteste Europiccola mit echter Patina, also schon auch kleine Rostflecken an der Hebelstange und nicht mehr ganz so blitzendem Chrom am Kessel und durchscheinendem Messing an der Dampflanze.
    Der italienische Verkäufer schickte sie mir mit einem losen Plastikschlauch anstelle des Glasröhrchens für die Wasserstandsanzeige, was auf den Fotos wegen des Metallschutzes fürs Röhrchen nicht zu erkennen war.
    Diese "Lösung" funktionierte irgendwie nicht:eek:
    Aber dank eines kompletten Dichtungssatzes von Francesco konnte sie komplett überholt und funktionsfähig gemacht werden.
    Nur die Spindel vom Dampfventil musste noch erneuert werden und leider zischt es dennoch minimal bei geschlossenem Ventil.
    Ist eben alles schon recht oft betätigt worden.
    Aber sie tut was sie soll, ist aber bei der Bedienung wieder etwas anders als die 1978er, was vermutlich an der massiven Messingbuchse in der Brühgruppe liegt. Für deren Demontage braucht man dann auch ein spezielles Werkzeug.:rolleyes:
    commodore und Li-Si gefällt das.
  18. #58 vectis, 17.04.2019
    vectis
    vectis Mitglied
    und hier noch die "spanische Tante" von Marcfi , die ich von Vincent aus Reims übernehmen konnte:
    Ebenfalls solide verarbeitet und wenig Spiel an der Gabel für den Handhebel. Und auch mit der Messingbuchse in der Brühgruppe, aber merkwürdigerweise ab Werk ohne Dipper-Rohr (wurde schon in einem anderen Thread zur Marcfi Graziella erörtert), so dass heftig viel Wasser durch den fingerdicken Kanal in die Brühgruppe strömt.
    Da müssen alle Dichtungen hundertprozentig in Ordnung sein...
    Auch mit ihr kann man wohlschmeckende Espressi beziehen;)
  19. NDNKL
    NDNKL Mitglied
    Zu spät ;)
    Bin mit meinem neuen Einersieb sehr zufrieden (dank Teil 99 - 1 Tassen Sieb La Pavoni Europiccola/Professional Ø54mm Innen / bis 2005)
    Leider scheint der Doppelauslauf festgefahren, er lässt sich nicht abdrehen. Wenn mal zu viel am Monatsende übrig ist, gönne ich mir einen bodenlosen Siebträger.+
    Ach, und die Sage läuft immer noch spitze! Zu Hause den Mahlgrad selbst justieren schlägt selbst das Mahlen in der Kaffeerösterei. Bin immer noch erstaunt was das für einen Unterschied macht (Crema!). Ein paar Tassen musste ich nämlich noch mit dem vorgemahlenen Bohnen schlürfen.
  20. joost
    Nur eine Frage des persönlichen Einsatzes :)
    Anmerkung: es ist ein normales Rechtsgewinde und einen Hebel anzusetzen kann viel Kraft ersparen
Pavoni: Handhebel hat viel Spielraum nach rechts und links - normal? - Ähnliche Themen
  1. La Pavoni: Diverse Fragen zur Mignon
    La Pavoni: Diverse Fragen zur Mignon: Hallo! Seit heute bin ich stolzer Besitzer einer La Pavoni Mignon - das ist das ganz einfache Modell, das es offenbar nur in Deutschland gab. Der...
  2. La Pavoni: ist meine Dichtung zu erneuern?
    La Pavoni: ist meine Dichtung zu erneuern?: Liebe Leute eine Frage: Ich ziehe den Hebel hinauf und es läuft einfach der Kaffee durch das Sieb - das Wasser hört nicht auf zu rinnen... Würde...
  3. Pavoni: Einer/zweier Filter -viel Dreck und Probleme
    Pavoni: Einer/zweier Filter -viel Dreck und Probleme: Hallo vielleicht finde ich hier Hilfe Mein Mann und ich habe ganz unterschiedliche Vorlieben bezüglich unseres Cappuccinos Ich nehme den...
  4. La Pavoni: es wird einfach nix...
    La Pavoni: es wird einfach nix...: Liebe Kaffeeexperten, ich bin am Verzweifeln. Ich versuche jetzt schon seit Tagen, unserer La Pavoni Europiccola einen halbwegs genießbaren...
  5. PAVONI: Druckrohr mit loctite + O-Ring?
    PAVONI: Druckrohr mit loctite + O-Ring?: Hallo verehrte Pavonisti, kurze dumme Frage: setzt Ihr einen O-Ring auf den Anschluß des Druckrohrs zum Pressostaten im Heizboden ein? Ich frage,...
